Trim error in V8 WIP
In the attached file, trimming half the circle using the 2 lines doesn’t work in (8.0.21293.4305, 2021-10-20).
Trim error.3dm (33.2 KB)
Thanks for the report and example.
https://mcneel.myjetbrains.com/youtrack/issue/RH-66026
@chuck will figure it out.
Are you settling into retirement comfortably?
I’m jealous as hell!
Yeah, It’s not too bad so far
Janet says Hi
Should be fixed in the next WIP. Take care Lowell.
@lowell
I just tested the fix.
Thanks
