Good day to all.
I am running out of juice again. May I ask again for some help? I want to create a railing from the offset curves I made as a floor plate for the next floors. (red curve). I hope to develop this with the same data structure as the basis curve (green curve). I am using curve indexes to offset it so it is needed to create a railing there but there are instances that some of the buildings will not offset some sides and will offset all sides. I am trying this without plugins.
Hi, sorry, this is part of a bigger graph and I already offset curves and that is the red one. In entirety you can select which side you want by human UI. but I just share the graph which is the next step.
Hi magicteddy, you helped me before on my other post. Thank you very much for that. Anyways you are right those areas are the one I need but the outer side/curves only. The plan is I can select which sides to offset(so it will create those areas) then I need to create a lower wall (a railing perhaps) but is it possible to make those sides the same index like on those exploded curve? It will be a very big help for me. Thank you.
