Trim Command, Amend Cutting Object Selection
the ability to undo a trim is great, but also I think a good option could be to amend the selected cutting objects. For example: doing a trim, it not working, Undoing, but you can’t then add an object you might’ve needed on reflection. Ending the command and running SelPrev doesn’t give you the selection used as cutting objects.
