Trim.Brep(Plane,Tolerance ) vs Trim.Brep(Brep,Tolerance )
Hi there,
I would like to use the Trim.Brep method in Iron Python, however I selected the Brep surface as cutter, Rhino still expect the Plane.
import Rhino
objBrep = rs.GetObject ( "SelectBrep", 0, False, False, None, True)
cut = rs.GetObject ( "Select cutter", 0, False, False, None, False)
cut = rs.coercerhinoobject(cut)
print objBrep.Brep().Trim(cut,0.01)
how about cut = rs.coercebrep(cut)?
Thanks for the hint. It works perfectly!
