Hi…,
I have drawn some curves with history. When I trim the green curve the red blend curves dance balllet. Bug?
blend_curve_with_history_doesnt_like_trim.3dm (36.2 KB)
Thanks
Michael
www.flexiCAD.com
Hi…,
Thanks
Michael
www.flexiCAD.com
Hi Michael - Hmm - yeah… so the rightmost blend curve is made with History, and the leftmost one is a mirrored, also with History, copy… correct? So a Trim to the green curve, the history makes the blend go ‘off’ - that’s the bug, the other side is correct, given the bug. So to speak.
Split does not have this result so far, use that for now…
It does break History,which it should not, since it is editing a parent. So - all in all something buggy here, but I suspect not necessarily easy to fix.
https://mcneel.myjetbrains.com/youtrack/issue/RH-43427
thanks for the report…
Hi Pascal,
yes, that’s right.
I purge history before, then trim works.
Thank you for your time
Michael
