Often when I use pipe for trimming a surface I got this “artifacts”. Is there an easy way to trim away those triangles?
yes, you can use SplitEdge near there and then, use _BlendCurve to make a round corner, with that curve, use _Pull to the surface and Trim it.
Thank you Diego. That works
