From the Picture, I want to trim surfaces 1 and 2 to where they intersect with surface 3. I’ve actually successfully used Split.Brep previously for similar tasks but this time round it wont work. Also tried using TrimBrep, but that seems to keep giving me the error “expected float, got Guid”, while the example on the help says you only require to submit 2 guids.
T add to that, I can also generate the curves at the edge of surface 3-I tried to find a way to split the surface 1 and 2 using these curves, but couldn’t do that either unfortunately.
Yep, here you are-It’s derived from a tonne of other curves and geometry generated from Python. Also, Any idea why when I generated Surface 3 (by splitting an arc surface where it intersected with surface 2), I get some rough edges at the bottom. (Attached a picture to see what I mean)
