TriGrid Dome Equilateral Members Kangaroo
Hey Everyone,
I’ve been trying to figure out a way to create a dome structure with equilateral, triangular faces (members will eventually be fabricated) using Kangaroo Line (Length), Pressure, and Bouncy Solver, but having trouble constraining the member lengths. Ideally the member length can be adjusted to meet the size goals of the dome structure (Radius 10-15 and Height 10-14).
Went the route of Polyhedron primitives, then decided to try and make this more adaptive as I couldn’t find a base to solve my needs. Any suggestions would be appreciated!
dome_v2.gh (23.8 KB)
dome_v2 Edited v0.gh (51.5 KB)
Thanks @Quan_Li - the above was retrieving naked edges in the middle of the mesh so I welded them and the above was working, but was curious if there is a way to contain the dome length members to a certain tolerance to find the ideal shape.
