Im doing a facade pattern and i would like to delete some triangles (points to be precise) on this pattern because they are too flat and it cant work like this. The fact is that the rectangle is to large but i need to keep it as it is. Here attached you can find the triangle types i don’t want to keep (green squares).
The process im trying to do is to delete points which are too close to the border of the frame. But it doesnt work right now…!
What is the easiest way to do stripes like here attached in each triangles (without the same steps).
In my first script i tried to separate the triangulation segments and then make different divisions of the lines to have something non uniform. Is it the best way for you?
