Triangle Panels around curve
Hi Guys!
How can I create a similar condition to this image on grasshopper where the lines of the triangle align?
Please and thank you.
Just use the Lunchbox.
thank you! but what if i dont want the building to be shaped like a tube. I wan it to be more kind of like this:
Is there a way i can extrude the base curve into a surface?
Please share a file including the surface.
Nautilus HexagonOnSurface.gh (9.7 KB)
@laurent_delrieu Hi, I try to use the HexagonOnSurface component in the Nautilus plugin, but there are overlapping hexes at the seam position. I am not sure if this is not the right case to use this component.
Hello
The result is normal I didn’t try to tile the ends. First purpose of this tool was for open tube. At the moment there is not recursion oprimization
Got It, Thanks!
