David81
(David81)
1
I am new to Rhino and this forum. Hello to the community and thank you for creating this lively environment.
I am playing with trees import. For some reason, some of the trees don’t show leaves after import, even though they are part of the imported model.
I haven’t found any way how to turn the leaves layer on. Am I missing an elephant in the room?
Using Rhino7, trees are sourced from the Turbosquid (FBX).
dk2079
2
do you see them in wireframe displaymode?
David81
(David81)
3
Yes, in wireframe and shaded mode the leaves are visible
You’re not seeing them in Rendered mode? Might they have a transparent material applied? Or some other material that is not showing up?
David81
(David81)
7
Sorted. Yes, there was 100% transparency set to the leaves material.
Now working fine:
Thanks a lot both for the prompt replies
