Every time I try to install it ¡ it appears ¡
I tried all the versions and different pages but the same thing appears to me all, I must think that my PC does not support it or there is another problem…
Well , thanks 4 Answer .
Hi - either use Windows Explorer
to navigate to your %APPDATA%\Grasshopper\Libraries
directory, or, from Grasshopper, open that directory from here:
Hi , Wim Dekeyser
I’m really grateful 4 your answer…
I wonder how to unlock the component
I heard about it but i don’t know what does it mean
This process that you show is what I did a lot of times but it does not work,
All ways that I installed tree 8 always this error advice appears
a reason should exist .
well, thanks a lot for answer …
Hi - It wasn’t unlocking of a component but unblocking of a file.
When you download a file from the internet, Windows automatically “blocks” it and you need to unblock those GH assembly files before you can use them. You need to right-click on the file in Windows Explorer, go to Properties
and then check Unblock
Also, from your screenshot, it looks like you are trying to open the file with Rhino and that won’t work.
