I’m wondering what the recommended procedure is for making Va objects (walls, slabs, doors) semitransparent - so that certain ones read as they would in ghost display mode. (But not using SetObjDisplayMode because it doesn’t last into another session.)
Is substituting their wall/window/slab/door style for one with the materials set to a transparent material the only way?
I see that VisualARQ objects do not keep their custom display object mode (using the command SetObjectDisplayMode command) after saving/opening a document. This is a bug, and I will fix it for the next VisualARQ version.
