JOHANNES8
(JOHANNES)
1
Is there a way to display transparent objects, i.e. objects where the environment is seen through, in AR-Mode.
It looks as if this functionality is lost when switching from the viewport to AR-Mode when the model has been embedded via iframe.
Is this functionality not yet implemented or can somebody help, please?
mathieu1
(Mathieu Huard)
2
Our team is looking into the issue and we will get back to you shortly.
Hello @JOHANNES8,
can you please provide us with a link to your model, than we can have a closer look at this.
For this simple model I just tried everything works as expected.
Cheers, Michael
JOHANNES8
(JOHANNES)
4
From your example it is obvious that a simple solution exists.
After some trial and error I finally found it. Transparency in AR-Mode only works with meshed objects.
Thanks a lot
