i am completely new on this forum’s stuff and scripting…
i am working on rhino osx and want to use this script found on the web (drop objects on surface) but it’s in format .rvb and i would like to translate it in python format to run it with pythonscript.
could anyone help me to translate it or does anyone have a .py with the same action?
thank you very much!
Option Explicit
'Script written by Damon Sidel
'Script copyrighted by Damon Sidel
'Script version Monday, May 09, 2011
Call DropOntoSurface()
Sub DropOntoSurface()
'Get surface to populate
Dim strSrf : strSrf = Rhino.GetObject("Select the surface to be populated")
If IsNull(strSrf) Then Exit Sub
'Get the points to drop
Dim arrObj : arrObj = Rhino.GetObjects("Select the objects to drop")
If IsNull(arrObj) Then Exit Sub
Call Rhino.EnableRedraw(False)
'Create jittery grid
Dim obj, k, x, y, z, line, csX, BB, p1, p2
For Each obj In arrObj
'Object information
BB = Rhino.BoundingBox(obj)
p1 = Array((BB(0)(0) + BB(2)(0)) / 2, (BB(0)(1) + BB(2)(1)) / 2, (BB(0)(2) + BB(2)(2)) / 2)
'Find point on surface to insert block
line = Rhino.AddLine(p1, Array(p1(0), p1(1), 0))
csX = Rhino.CurveSurfaceIntersection(line, strSrf)
If IsArray(csX) Then
For k = 0 To UBound(csX)
If csX(k, 0) = 1 Then
p2 = csX(k, 3)
Call Rhino.MoveObject(obj, p1, p2)
Else
Rhino.Print "Intersection is not a point"
End If
Next
End If
Call Rhino.DeleteObject(line)
Next
Call Rhino.EnableRedraw(True)
End Sub
I don’t know how the objects are supposed to be set up to make this work - it looks strange - are you sure you have all the script and 100% correct? If I run the vb Rhinoscript, I get a type mismatch error on line 30…
i tried it in rhino for windows and it works fine, be sure to have all the objects and the surface above the z:0 i send you again the original script
thanks!
Option Explicit
'Object information
p2 = csX(k, 3)
Else
End If
Next
End If
Next
End Sub
def DropOntoSurface():
strSrf=rs.GetObject("Select the surface to be populated",8)
if strSrf==None:return
arrObj=rs.GetObjects("Select the objects to drop")
if arrObj==None:return
for obj in arrObj:
bb=rs.BoundingBox(obj)
pm=(bb[0]+bb[2])/2
lpi=rs.ProjectPointToSurface([pm],strSrf,(0,0,1))
pi=lpi[0]
rs.MoveObject(obj,rs.VectorCreate(pi,pm))
DropOntoSurface()
it works fine! Now I have to study a little python to understand what did you write…
Is it possible to set that the objects merges completely into the surface? (the image is the result of your script), it’s for a urban model, so the buildings have to be dropped on the topography, so i can make a boolean with the two entities.
I have a vb script that I made to do just this, it’s rather more involved as it can also accept meshes as volumes to project as well as to project to… you can also project to multiple overlapping surfaces or meshes. There is a choice to either let the volume stop at “first contact” (the object stays above the surface) or become fully embedded in the surface… I also use this for siting buildings for small scale models.
I can look at “pythonizing” it later as it’s over 100 lines of code…
OK, so this is just a simple projection script, I don’t know why I thought it was supposed to distribute the objects on the surface, must have confused this with another post…
OK, here is the Python version… In the meantime, I also found a bug in the vb script, I will attach a fixed version of that as well. What I stated above about multiple overlapping surfaces was not 100% correct, it will do them, but the the projected volumes will not stop at the upper surface. That will be corrected in a future edition.
