Transforming the base model to cubic diamond structure version
Hello
I made a chair drawing on Rhino and I need to convert this drawing completely to cubic diamond structure. I am sharing the files of the chair and cubic diamond structure. I need to do it using Grasshoper. Can you help?
Thanks a lot.
sumy diamond.gh (17.3 KB)
sume_c.3dm (1.6 MB)
(I want to change this model to diamond cubic)
(Like that)
Please try to use IntraLattice to achieve it,
IntraLattice.gh (57.2 KB)
Hello
I already help here.
But without opening your file it seems that your object is not a solid. So it has no interior no exterior!
You’ll have to make it solid (give it thickness)
I opened the Grasshopper and I see no modification from what I posted and no use of the other script I posted there
So I think you want someone to do the job at you place. Not sure you will learn a lot!
OT: that reminds me Joris Laarman’s bone chair :heavy_heart_exclamation:
https://www.google.com/search?sca_esv=a557d55a5821a027&sxsrf=ADLYWILqvA_hQlekDFYelq9fqNSE1tCqPA:1734388745370&q=bone+chair+joris+laarman&udm=2&fbs=AEQNm0AhtDknupEF8_qTQA8ksbc_ApAFdfCx4z-pmFMoZwUOPJaCnYygt8FiZDPTsw4TuYYnbiJmCbdVpJAwkCqxA4UGMw7Us2Jwiz61U6ZMWTB4wBLpmIgjem61k3P8Ml0LxrSWzqqWbE3RKWGTN9O57LCpxY7pLB6MO7YJmzl_DIvllNbQkj7YsMHu8RplGiWSihFTzVHf&sa=X&ved=2ahUKEwj6vsfIra2KAxVWhf0HHYC_JHwQtKgLegQIEhAB&biw=1688&bih=872&dpr=1.1#vhid=7fq4mqGxEkbnlM&vssid=mosaic
hi,Is there a source that explains how we can give thickness and surface it as a model for cubic diamond?I downloaded lattice and tried to write the code but it didn’t work. Can you help me?
FYI,
Heya - intralattice or Dendro are a good way to go if you just want a diamond lattice.
But I’d also like to make a plug for my component library Horta.
Being honest- it’s less easy to use but that’s because it has a LOT of options and flexibility. Rather than approach making single recognizable lattice patterns it is built to be able to implement all 230 patterns of the “Space Groups.” I haven’t recorded a tutorial or made any presets. Which I should probably do at some point. But if you wanted pointers on how to use it I’d be happy to share.
So - download one of the others to bang out your one project. But also download Horta and play with it and see how far the same concept can go!
hi, Have you done anything else here besides assigning the geometry to the subd in addition to these components? thanks
You need get a closed object, I used some SuBD related commands to close this modeling.
hi,I have made the design but I need to edit it for 3D printing optimization. I am downloading Horta. I ask you to show us how to optimize it.I send you the design
sume_c.3dm (1.6 MB)
