Transforming technical drawings into 2D files
Is there any extension or standalone software that can translate a technical drawing into a 2D file that I can import into Rhino?
I need to draw pretty simple pieces, but it’s very time-consuming.
3593_COMM_233834_1_2.pdf (25.6 KB)
Hi Lorenzo -
You might need to provide more information because the PDF file that you attached imports fine into Rhino:
sorry, I forgot to mention that the clients’s drawings are not precise, but the measurements are.
I did not send the originals because I did not want to have problems with the client.
What’s your actual workflow then?
If you are asking if there’s a software package that can take an engineer’s or designer’s dimensioned sketch and turn it into an accurate drawing in the completely general case: no, there isn’t.
If you have a more specific use case, you’ll have to describe it to get a useful answer.
Thank you, this is what I needed to know.
I don’t believe you and I’ll ask ChatGTP.
