I’ve got a sink with specific dimensions and i need to change the width and lenght without changing the model.
Scale is not an options as it changes the structure for the sink and the hole get’s oval.
Now these dimensions need to get adjusted someway or another.
For example, the drawed model dimension is 500 x 300 mm.
And i need to get it to 800 x 520 or any other dimension.
I will try to redraw the model, with the knowledge i allready have.
It seems a difficult model to create, but that’s just because i’m fairly new to grasshopper i gues
I would start by testing the workflow in rhino, just to fiddle around and see if the order of steps is clear and then reproduce in grasshopper afterwards.
