Transform Method
How should I define the argument, guid, when I use the transform method in a foreach statement?
Guid IndexTest = ///???///
foreach (Curve Item in curves)
 Transform transformA = Transform.Translation(move);
 Transform transformB = Transform.Scale(center, radius);
 Transform transformC = Transform.PlaneToPlane(planeA, planeB);
 Guid testA = doc.Objects.Transform(///guid, transform, bool///);
 Guid testB = doc.Objects.Transform(///guid, transform, bool///);
 Guid testC = doc.Objects.Transform(///guid, transform, bool///);
 ids.Add(testC);
 doc.Views.Redraw();
if your curves are document objects, it would be Curve.Id
That apparently causes an error.
I was assuming your curves are curve objects. Is this not the case?
When transforming document objects just pass them directly into the doc.Objects.Transform function: one if the overloads take RhinoObject as argument.
If your curves are not yet in the document you can use the Transform method on Curve: Curve Class or the other functions Rotate, Scale, Translate…
Is this the same idea?
A BrepObject is derived from the same RhinoObject baseclass as the CurveObject, so yes, same idea.
Hi @jack3,
You might consider doing something like this:
foreach (var curve in curves)
  var xf_move = Transform.Translation(move);
  var xf_rotate = Transform.PlaneToPlane(planeA, planeB);
  var xf_scale = Transform.Scale(center, radius);
  var xf_final = xf_move * xf_rotate * xf_scale;
  if (xf_final.IsValid)
    var new_curve = curve.DuplicateCurve();
    if (new_curve.Transform(xf_final))
      doc.Objects.AddCurve(new_curve);
doc.Views.Redraw();
– Dale
