Transform component bug
There is a bug in Grasshopper.Kernel.Types.Transforms.Generic which causes a Param_Transform with PersisentData not be recovered or copied ok.
The problem remains in Serialization Read Method, (Line 97, Using DotPeek Decompiler) which overwrite a matrix field with a wrong value.
Regards
Hi @Harper
that image did make it through to the other side. Can you edit your post or re-upload it?
