Transform and remove original geometry
How can I transform, in my case using two stacked RotAx modules in grasshopper, and then remove all geometry except the final surface meshes?
too vague
What?
I have set of surface meshes as input geometry. I want to rotate that geometry and just get the final product out without have to manually delete the original geometry.
Continuing the discussion from How to ask effective questions:
Rickson, this is my first question on here. Do I need to explain what geometry is? Or what a rotation is? I literally had to create the script on the right just to rotate an object the way I precisely wanted.
I have geometry
I rotate it
Rhino and Grasshopper keep both. They copy the geometry to transform it.
Is there a module or script or something that I can use to systematically delete the original geometry.
Is there a script or function in Grasshopper to delete geometry?
geometry = a set of surface meshes
Depending on the workflow you can right click bake to a particular layer, then delete the original if need be.
One way would be to use worksessions to reference in your geometry, then bake into a new file.
Most of the people that answer questions are at work; so posting relevant geometry, overall goal and specific questions will get you answers quickly. Hence the “how to ask effective questions” sticky – it really is important.
I am currently using the right click bake and delete method. I would consider that a manual approach. I am looking for something more robust especially when my geometry is a set of surface meshes and small rotation creates difficult navigation into regions hunting for the right mesh to delete.
bake into a new file? can you elaborate?
The overall goal is to remove the original geometry.
Hi.
See if this helps:
I use elefront for these types of operations.
The Bakename will replace any previously baked instances, you can also modify the layer of the original geometry to a delete layer as you bake the new geometry. Easy to demo if you posted a file.
Elefront is useful and could be combined with Rhino worksession.
“The Worksession command manages a list of models that are being used as reference geometry.”
https://docs.mcneel.com/rhino/6/help/en-us/commands/worksession.htm
