Transform 1 line segment of triangle into curve
Challenge;
There is a triangle. (with 3 straight line segments ofcourse :)).
Line 1
Line 2
Line 3
Quesions:
I would like to transform Line 3 into an ‘arc/curved’ line segment,
whereby the curve is controlled by the length between the middle point of point Line 3 and the ‘opposite corner’ point. (X).
In a way that It is possible to play with the angle of the curve, by modifying the distance between these points.
Any suggestions?
Thanks :slight_smile:
2020-06-25 Curve a triangle line segment.gh (5.4 KB)
Curve a triangle line segment_2020Jun25a.gh (10.3 KB)
Curve a triangle line segment_2020Jun25b.gh (12.9 KB)
Curve a triangle line segment_2020Jun25b2
Ahh thank you!
Very helpful! :slight_smile:
The first solution was already good!
Only 1 favor to ask, would it also be possible to play with the distance between the middel point of Line 3 and the middle point of the curve? (instead of the distance between the ‘corner point’ and middle point?
Thank you again! :+1: :+1:
