Transfer texture from hi poly mesh to low poly mesh
Hello All,
is there a workflow for transfer of a texture from a hi poly mesh to a low poly mesh in Rhino 8 ?
For example, transferring the texture from a hi resolution 3D scan to a reduced poly copy of the same scan.
I know it can be done in Blender etc, but can it be done in Rhino ?
Thanks
Mike.
Check out this video from @BrianJ fixing the problem on my test file.
Thank you Martin / Brian, that is exactly what I needed !
Regards,
Mike.
