Hi…
This is a draft, done for fun… double check, everything could be wrong.
Step 1:
I’ve used some c# to build up a mesh from the gradient;
then manually set (from Gh to rhino 3d environment) a line from the center of first gradient cell to last gradient cell;
then subdivided the line by proper count (16) and used evaluate mesh to get color of cell centers colour;
converted that list of colours to points and made a polyline;
This could be a “gradient-3Dpolyline” … (what? )
Step 2:
Created again another mesh from your thermal map and converted each colour to point;
found normalized parameter (closest point) to the polyline and use that value to move mesh vertices in Z.
(with my c# code each mesh have x-1 and y-1 dimensions as each pixel “become” a vertex of the mesh)
RGB to height_maje.gh (20.3 KB)
I’ve searched for your original thermal map, but all i’ve found was a similar one with text over it…
So I had to recover and extract your original image from the image sampler of your gh file
(This was the hardest part … LOL)
Gradient too
(I’ve recycled the c# code from here How to map a set of different geometries to different values on a surface? - #6 by maje90)
