Transfer of vertex normals smoothness between objects
Transfer of vertex normals smoothness from a donor mesh/polysurface/subd to the other mesh
Is that possible in Rhino?
Any ideas on how to do this in Rhino (transfer vertex normals)?
Blender plugin also has something like that: MESHmachine 0.6 - Normal Transfer - YouTube
It would be great for me also transfer smoothness from normal maps (texture image) to mesh
vertex normals.
I want to use that after processing the decimation of some car part scans to have mesh heavily decimated but smoothness would come from high-quality scans or from normal map texture (which could be generated as the difference between low and high polygon meshes).
In Rhino I want only to transfer normals from one mesh to another or from a normal map to a low polygon mesh. Rest I will do in other apps.
There is also a way to use freeware MeshLab software to transfer Vertex Normals from one mesh to the other: MeshLab Features: Vertex Attribute Transfer - YouTube
Do you know how to do it in Rhino?
As far as I know, Rhino doesn’t have this. @nathanletwory do you have an idea if this is possible?
You probably will have to do some programming:
I don’t know if Rhino will never overwrite any custom-set normals as the result of any operation on that mesh.
