Can you make the touchbar customizable so that you can select which commands exactly you can use?
Nope.
This would be a great inclusion for future versions of rhino. I’ve managed to do it in an app better touch tools and is way better than using on screen commands. Especially for frequently used commands. A fantastic implementation would be to have the touchbar display your most recent commands as well as you most used automatically.
this would be greAT!
I forgot to mention in addition to the previous comment another additional feature for the Touch Bar that would cut on time, especially for beginers. If after you run a command, the Touch Bar displays the options for that command like: move>vertical yes or no, or extrude surface>solid yes or no. It would be a much faster double tap.
