Totally weird toolbar phenomenon
I have a number of toolbars with custom scripts, including one for STL exports with predefined settings. I am building a test part and I went to export it as an .STL with one of my predefined settings. I first preselected the part and then hit the flyout toolbar and picked one of my preset buttons. The export dialog showed up asking for the file location as programmed, but - surprise! - I also had the ENTIRE script show up on the screen to the left. I have never seen this happen before.
If I do not preselect but first hit the button, then select the part, then the script does not show up…
Totally weird! @CallumSykes - something for you I think… I have found a couple of other glitches as well currently, will post separately.
Video - first post-select, then pre-select, same button.
@Helvetosaur this is a known bug and happens only with the new Eto command UI. It’s on @curtisw list
What you can do for now is switch to the legacy commandline (TestEtoCommandUI)
OK, since my command line didn’t look any different, I didn’t realize that was activated - I guess it is now by default. Setting it back to legacy does indeed fix the issue for now, thanks.
RH-97041 is fixed in Rhino BETA
