Total Radiation Analysis Problem
Hi!
So I created this shape optimization definition for minimum solar heat gain, but apparently when i tried running the analysis, the total radiation shown is too little to be true? (Only 11.92 kWh/year?) and i tried to check it with the sum of radiation result and then multiply it by the total area of geometry, and it showed me a really big result, unlike the total radiation… is there something wrong with my definition that caused the total radiation so small? Thank you very much! Polygon Base with Rotation.gh (443.9 KB)1612761009670
if you state your used plugin and categorize your topic you might find help faster.
i am just guessing you used ladybug? if so there is also a dedicated forum for it.
yes, im using ladybug, I tried searching the ladybug category earlier but i didnt find it. Maybe i will try to post the same problem in the ladybug forum. Thank you for letting me know!
