Vertical polyline displayed normally in the top view in Rhino5 are not displayed in the Rhino7 top view.
Hi - please run the Rhino SystemInfo
command and copy-paste the result here. It looks like you might be running an outdated version of Rhino.
This is the latest version updated yesterday.
Rhino 7 SR6 2021-4-20 (Rhino 7, 7.6.21110.13001, Git hash:master @ 2e367bb5473238ebf7cfec4891ea72958ce57539)
License type: Commercial, 빌드 2021-04-20
License details: Stand-Alone
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 (NVidia) Memory: 8GB, Driver date: 1-22-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.40
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-22-2021
Driver Version: 27.21.14.6140
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.6.21110.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.6.21110.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.6.21110.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.6.21110.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.6.21110.13001
Thanks.
We have this issue on our list as RH-53520.
As a workaround, you can increase the curve display width to 5 in the display mode settings. At that point, the curve becomes visible head-on.
This is not a workaround. This is because all curves are displayed thick. As in the Rhino 5 version video, it should be displayed in pixels when the thickness is 1.
RH-53520’s display width 5, which is the answer to the previous inquiry, is not a solution. The reason is that the normal front view, side view, and perspective view all appear thick, which interferes with visibility. Like Rhino 5 version, when width is 1, it should be displayed as 1pt in topview.
Also, if the width is greater than 5, it is displayed in the Top View. It doesn’t make sense that the widths from 1 to 4 are displayed as 0pt.
Hi - I’ve merged your last post into your previous thread - there is no reason to start a new thread.
As I said, the issue is on the list as RH-53520. I never said that setting the display width to 5 px was the solution to the issue, it’s a workaround in case you absolutely need to see curves head-on. Of course, this will affect the thickness in all viewports in the same display mode.
Are you saying that you are making corrections so that you can see 1pt in topview?
you are so cool!
Hi -
As stated in that YT item, my expectation is that it should work as it does in Rhino 5. It is on the list of a developer to look into this.
한국인이신가요?
전체 폭파 하신다음에 떨어진곳 제어점 킨다음에
setpt툴로 xyz모두 체크해서 하나로 모아보세요 그다음에 다시 결합
The RH-53520 number is a topic that has been published two years ago, but I hope this time it will be resolved.
thank you!
참고하겠습니다.
