Topology map with relaxation zone on the borders?
Hello everyone!
I created a topology map from GIS data and imported it into rhino 5.
I build a solid out of it (to end up with a stl file). What I need to do now
is to put a relaxation zone around to topology to end up with borders
that are on the same height on the east/west and south/north ends
of the topology. This should be done by using a spline …
I’m new to rhino, so is there a tutorial or a guide or someone out there
how could point me into the right direction to do this or provide me with
a link where I can see how this is done (maybe youtube or something)?
Thanks a lot!
Best, Thomas
Hi Thomas - I’m not picturing the situation very clearly- can you post an example file that shows what you’d like to do?
thanks,
Dear Pascal,
sorry for the delay … the holidays … :slight_smile:
I uploaded a hand drawing of what I need to
do to my dropbox … have a look at this link
please …
It is a pdf. I forgot to add to the text written on it that the terrain
stl 's lowest point could be at maybe z=400 and the plane below
the terrain needs to be located at that lowest point.
I would be happy to install additional tools (free) if I have to.
Thank you very much for your help!
Best. Thomas
Hi Thomas, if you can post an actual mesh file to work from there is more hope that I or someone can help…
Dear Pascal,
here is a link to a STL file I am working with …
I hope this helps to clarify things a little more …
Thanks a lot!
Best, Thomas
Hi Thomas - probably not there yet but here is a first shot at what I think you might want, maybe…
Terrain1_PG.3dm (880.5 KB)
Dear Pascal,
what exactly did you do to the file? I need the terrain in the end to
look like this
I just used “Drape” to throw a net (?) over it and then used “cap” to create a solid.
But I am loosing a lot of detail in that process. Anyway my result is Ok for now.
Is there a way to transfer the lower left corner of the “Drape” and “Cap” process EXACTLY to
x,y,z=(0.0, 0.0, 0.0) ? How is it done? A tutorial would be nice … any links maybe?
Thank a lot!!
Best, Thomas
Hi Thomas- does this get any closer?
Terrain2_PG.3dm (223.5 KB)
Terrain3_PG.3dm (384.0 KB)
Dear Pascal,
that one look pretty neat! How did you do it?
Best, Thomas
Hi Thomas- ok, here we go - (for the second file, called terrain3, which I think is a little better and much simpler to make)
  • ExtractMeshPart. Select a starting polygon on the terrain part of the original mesh. This should isolate the terrain from the box part of the mesh. Hide or delete the box.
  • Patch on the mesh. I used 30 by 30 spans - that should be plenty if the terrain is relatively ‘soft’ as in your example.
  • Turn on points for the mesh and select all the outer points. Here is a macro that will do that if one surface point is selected:
    SetRedrawOff _SelU _SelV
     _NextU _NextU _NextV _NextV
     _PrevU _PrevV
     _InvertPt _SetRedrawOn
  • Use SelConnected to select the next rows of points (or make a similar macro that selects two rows)
  • Use SetPt in Z only to set the level of these points.
  • Select the third row and Smooth in Z a number of times ro relax that area in Z.
Any luck?
