TopMod 3D: magnetic field lines as geometry (pipes, handles, 2D/3D)
New in TopMod 3D: Field lines — magnetic field lines between poles, built as real geometry.
Field lines run out of every north (+) pole and curve into the south (−) poles, like iron filings around magnets. You drag the poles around in the viewport and the lines re-trace live; drag a pole’s orange knob to change its strength, click it to flip N/S.
  • 3D or 2D — lines in space, or flat in a plane (good for laser / plotter work)
  • Pole layouts: scattered, bar magnet (dipole), quadrupole, ring of alternating poles, or poles at your model’s corners
  • Line styles: round pipes, thin lines, or TopMod-style handles (full width at the poles, pinched in the middle, with optional corner twist)
  • Lines per pole, thickness, sides, reach, arrows along the lines, pole spheres
  • Works as a live modifier in the stack, so you can keep editing the poles later
With the TopMod 3D for Rhino plug-in the result streams into Rhino live as a polysurface / mesh while you move the poles — bake it when you like it.
Install: _PackageManager → search TopMod, or download from food4rhino: TopMod 3D | Food4Rhino
Web / iPad: TopMod3D · TopMod 3D v3.0 free topological mesh modeler, online + iPhone | AMAXiMAL
iPhone / iPad app: ‎TopMod 3D: Design Software App - App Store
Feedback and ideas for other field / physics generators very welcome.
More: AMAXIMAL.com/topmod
