我正在学习Grasshopper,在这个教程说明中发现一个问题:
如截图所示,我下载了附件,发现教程示例中的过程可能是有问题的。
Your equality filter appears to be from an outdated version can you please check and update if possible?
You may also want to post your system info…
Rhino 8 SR5 2024-2-27 (Rhino 8, 8.5.24058.13001, Git hash:master @ eaa901528453bac5a3cfc23321bdf4d767238d34)
License type: Kommerziell, build 2024-02-27
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.16
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 22GB, Driver date: 2-7-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.52
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 2-7-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-7-2024
Driver Version: 31.0.15.5152
Z-Buffer depth: 24 bits
Total Video Memory: 23028 MB
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24058.13001
这里确实写错了,结果应该是 5 个才对。
Hi @Vanessa
There is a small error on the following guide page.
Grouping and Filtering Data (rhino3d.com)
In the section discussing the filtering process using the Smaller Than Filter
component, there is an error in specifying the Key parameter, which has led to incorrect results.
The correct result is shown in the following image.
Could you please fix it?
Thank you,
-Jorin
的确是5个结果,我截图说4个是错的。
反馈很及时,这个论坛真的很棒。
非常感谢!
@JorinChi - This should be fixed, Rhino - Grouping and Filtering Data.
