현재 한글로 설치했습니다.
영문으로 재설치하는 방법이 있을까요?
In Windows applications listing select Rhino app and choose to modify the installation. In the installer you can then select also English.
Also, please keep the communication here in English if possible (although I try to learn Korean I’m far, far, far from knowing enough, nor does most of the forum members know Korean I think)
새로 설치를 하면 자동으로 한글로 다시 설치가 되고있습니다.
현재 저는 MAC을 사용하고 있습니다.
Ah, on the Mac you can just go to Rhino 7 > Preferences > Language. Select English there.
I don’t know the Korean names for these menu entries though, so hopefully that helps still.
감사합니다! 해결했습니다^^
