Toon or special effect material on regular shader
Hi there,
is it possible to create/render a toon material (or any other special effect material) on the regular shader, among other parts having a normal rendering mode/material?
My goal is to be able to “ghost out” some parts which are not relevant, having no shadow applied to it or only having a contour, but leaving the other parts which I want to focus on with regular rendering material/shader?
Something similar can be achieve in Keyshot with a Toon material.
See example below, where I only want to focus on the grip material.
Thanks in advance for the support!
Kind regards,
Gabriel
Hello Gabriel,
You can use the _SetObjectDisplayMode command and apply the render view to the objects.
Wolf
Hi Wolf,
Not exactly what I was looking for, but definitely does the trick.
Thanks for the hint!
You need only to change the visual style and you should get what you are looking for.
You set all objects to a chosen style and the general style to render or do the opposite.
See for styles the link below.
Wolf
