Tooltips are crowded
Just noticed this:
Doesn’t matter if the icons sizes are changed. This same issue is present.
Thanks,
Dan
Mine is fine here
Have you changed your Windows font scaling in Control Panel?
Yes, I’m using a 4K monitor and I have it set to 150%. The already too small tabs are microscopic if I attempt to run it at 100%.
Hmmm…
This is supposed to be working well for V6 now.
Maybe @stevebaer will have some ideas.
What are the details of your display setup?
It is probably just a scaling bug that needs to be addressed with 150% text size. JB, did you make a youtrack issue for this?
@stevebaer
I will do if I can duplicate it.
Not sure what details would be useful. 28" UHD display as the main monitor, 24" as secondary. FYI… if I move V6 to the secondary (1920 x 1080 at 100%) the issue is still there.
Nvidia Quadro K5000 card with slightly out of date drivers (March 2016).
Anything specific you need to know?
I was able to duplicate it so it has been buggified:
https://mcneel.myjetbrains.com/youtrack/issue/RH-36424
I probably should have mentioned this is Win10.
And since we’re on the subject of tabs:
Just a reminder.
Thanks,
Dan
It happens in Windows 7 too. It’s a Rhino display issue independent of the
operating system.
The tool-tip problem should be fixed in the next release.
RH-36424 is fixed in the latest WIP
