Ever since I upgraded to Version 5, I have not been able to figure out how to display the icons for making curves, surfaces, and solids. There are tabs that are labeled with these things, but simple things like lines, rectangles, and circles don’t reside in those tabs. I have to use the pulldown menus or type the commands. OK, but I got in the mode of using the icons and like that better. How do I get to them? thanks, rex
Hi Rex - by default the left hand vertical toolbar should update with these tools when you select the Curve Tools tab, for example. If you do not have a vertical toolbar showing on the left, then please look in Options > Toolbars > Size and Styles for “Sidebar visible” and make sure that is checked. Any luck?
Alright, that did it. The Size and Styles button wasn’t intuitive to me so I didn’t push it in my wanderings. I should have gone there anyway.
thanks much,
rex
