Toolbar Layout panel glitches
Hi!
When opening menu Tools > Toolbar Layout, the panel is too high. It’s header bar is off screen, so it cannot be moved, and the buttons at the bottom are cut off. Happens when Rhino is fullscreen, and window mode.
Top:
Bottom:
Furthermore, the icon to delete a toolbar
is not working. The dialog “are you sure” pops up, but nothing happens then.
Thanks!
Edit: after focussing on another app, the back to Rhino, the toolbar panel/window resized itself, so that it wasn’t cut off anymore. It remembers it’s size then. So, it’s nothing really dramatic.
this is already on the list as RH-72216 Tools Toolbar layout gets partly invisible
thanks for reporting, logged as RH-72461 Can’t delete toolbars from Tools>Toolbar Layout
