Hello - you could use a script like the one attached here - you’ll want a bit more than this to set the exact options - I just made some up here. You may also want everything selected automatically, and exported, but this should get you started, it seems to work OK here.
Perfect! Thank you
This is exactly what I needed. Somehow I am very slow to pick up the syntax and start writing on my own. Adds to the confusion the mixed styles of Python and the default Rhino Script.
Could I shoot another fast question?
I have this line for Rhino Script and for some reason I cannot figure how to pass on the settings again. I try to follow your logic with the script you shared but I can’t get the syntax right:
Where strOpen is the full path to an .igs file.
The line does work but after it does its job I cannot pass _Enter _Enter to just confirm the default settings, or passing custom settings also doesn’t work.
