ToNURBS vs MeshToNurbs
What is the difference between the new command ToNURBS and MeshToNURBS?
Where did you find the command ToNURBS? My version of V6 doesn’t have it.
Hi all - ToNurbs will replace MeshToNurbs at some point - the idea is that it will work on meshes, extrusions, eventually SubD objects etc. It was there then yanked because the developer thought it not ready yet. There might be some debris still left in the UI though, I’ll take a look.
It’s still in as a test command - i.e. you have to type the entire command name.
It is documented in Dale Lear’s SubD Status document.
