My definition creates triangle frames.
At same elements Solid union fails. If I change the tolerance from 0.001 to 0.01 those elements which was wrong become OK, but others fail. Since it is high number of elements I cannot always chnage the tolerance and check whether the result is OK. Is there way to set the tolerance within Grasshopper?
Any suggestion for getting good results always?
