Toggling visibility of geometry
I tried this, but even when off, there is still the surface edge faintly visible:
2024-04-17_toggle_visualization.gh (8.8 KB)
Is there a better way?
Background: For better understanding of a complex definition, I would like to be able to visualize specific geometry with the touch of a button. Such geometry is for example a surface that gets populated with points. It is not part of the final result, but the surface is nice to see once in a while in order to get an idea of what’s going on.
Use a Stream Gate or the new Rhino components:
2024-04-17_toggle_visibility.gh (8.6 KB)
Thank you very much!
The Stream Gate solution I should’ve discovered myself. It’s very Grasshopper.
The new component solution is quite interesting, didn’t know about this option at all.
