hiya
more silly questions
I did google first but can’t find an on/off toggle for text dots ?
I have unrolled a surface and would like to turn off the numbered dots, not delete them just toggle.
Richard
hiya
Richard
You can use this macro:
_SelDot _Hide
It’s possible to easily assign a keyboard shortcut (or alias) to this macro:
wow that was a fast reply,
Thank you I’ve not used assign yet so thats 2 things you’ve taught me today
Thanks
Richard
hiya
not as easy as I thought , do I need to add a macro script or is typing in the command enough ?
It doesn’t seem to work for me .
Richard
Hi @fragged8,
It looks like there is a typo in the screen shot: The command is _SelDot _Hide
, not _SeldDot _Hide
. Also, remember to put a space between _SelDot
and _Hide
-David
If you want to use it in command line, first you need to run SelDot
and then Hide
Running Show
command will bring the hidden text dots back.
P.S. you can use Ctrl+H and Ctrl+Alt+H to run Hide
and Show
command.
Hiya
Thank you @Mahdiyar and @DavidEranen that cured it , I did clock the space and took it out DOH ! but thought the other ‘d’ should ahve been there .
All working now, that is going to make things a little easier when I have about 200 dot heeh
Thank you
Richard
If you want to take it one step further, you can show dots that are hidden with
! _ShowSelected _SelDot _Enter
