Today's beta update wiped out everything
I installed the update this morning and when I opened the beta all my settings, toolbars, etc. were gone. Of course I had backups just in case this happened. But when I try to use my saved settings or my saved toolbars they fail to load. Check this out:
I can get the panels back where I want them in a couple of minutes. But the inability to import my custom RUI has me worried. Please don’t tell me I have to re-do it!!
Thanks,
Dan
Same thing for me.
Does this include none UI items such as Aliases, Mouse Settings, Display etc?
YT to track this here - RH-97739 All settings wiped on newest Beta
I’ve been backing up my .ui file. Is that enough to prevent loss, or is there more I need to backup?
Your best bet is to run OptionsExport and keep a copy of that .rhs somewhere.
Hi Callum,
I will check in the morning and let you know.
Thanks,
Dan
hi @CallumSykes, will you guys post a fix this week in a new build? thx.
G
Well…could be worse..
Like clicking cancel that changes some settings to default…
Hey everybody,
Try going into Window Layouts and select the default layout. That brought missing toolbar and sidebar items back for me.
If you have a saved layout obviously you can select that instead.
HTH
Jeremy
Once I know what the issue is I can give a good answer to that
that helped indeed all was gone, but still a lot missing custom popup gone also, and i can not load the backup toolbars i made
Hi Callum,
It looks like the aliases, mouse settings etc. are still there. What was wiped out seems to be the containers holding panels and toolbars.
Thanks,
Dan
Hi Jeremy,
I wasn’t aware of that. It didn’t save the day, but I will certainly save out my windows layout once it’s back to how I want it in case this happens again.
Thanks,
Dan
I did this yesterday and the toolbars came back. I closed and re-opened the beta and they were still there. I opened the beta this morning and they had gone again. I selected the default layout and they came back. I closed and reopened the beta and they were still there.
Let’s see if they disappear overnight again…
EDIT: OK, so if you do this (select the default layout) you can close the Beta and the toolbars will still be in place just for the one next time you reopen it, after which they disappear again!!! You have to select the default layout each time you run the beta to stop them disappearing. @CallumSykes
The answer seems to be yes, check DMs :slight_smile:
