To Slice or.. Something Better
I’m projecting lines onto objects in hopes that I can use the projections to create more surfaces on the solid objects with them. I can’t find any option to do this beyond slicing a solid with a line and joining it back together. Does anyone know a slick way to do this? Thanks in advance
Splitting Surfaces.pdf (489.6 KB)
Hi Michael - hard to be sure without a file but SplitFace may be what you are after.
That is what I’m looking for thank you. Is there any way I can get splitface to operate with curved lines instead of straight lines?
Hi Michael - use the SelCurves command line option. That is a weird option name, we need to fix that.
RH-82492 SplitFace - command line option name
Beautiful! Thanks
