I want to know a method to display “mesh colorbar” in Rhinoceros
and the method to zero the center of the colorbar.
20180901_GH-Q_colorbar.gh (11.7 KB)
The above is a program
Mesh and numerical value become known.
The indication to the first Rhinoceros
I want to obtain such a result
and
Negative is displayed by orange when I remain present program
There was a similar thing on a internet,but did not work well.
Thanking you in advance. I need your help!
Momiji
HS_Kim
August 31, 2018, 5:05pm
2
The range of your number is not symmetrical on both sides with zero as it’s center.
If so, you could use graphmapper to extend of positive range.
20180901_GH-Q_colorbar_re.gh (16.5 KB)
You’re very kind. It is the program that I want found
Numerical value is that the minus becomes all colored it in the case of “plus”, how is it good?
In addition, colorbar of “1 to 0” appears when I display colorbar on Rhinoceros.
20180901_GH-Q_colorbar_re_re.gh (17.2 KB)
I need your help.Thank you!
HS_Kim
September 1, 2018, 6:37am
4
It seems you don’t know much about the Remap .
There are many other way to remapping your numbers, Graph mapper is just one way and if it does not fit to your case, find and try another way.
20180901_GH-Q_colorbar_re_re V2.gh (19.6 KB)
You are very kind!
I learn a little more about Remap.
Thank you!
