Title: Need downgrade link for Rhino 8 Mac (SR 8.4 or 8.5)
Hi McNeel Team, I am running a MacBook Pro with an Apple Silicon M5 Pro chip. My current build (8.36) is permanently stalling on the ScriptEditor initialisation progress bar. This environment issue is causing my Grasshopper Ladybug Tools components to crash the entire application instantly. I need to downgrade to an earlier service release (around Service Release 8.4 or 8.5) where the scripting environment functioned correctly on my machine. Could you please send me a private direct download link for that Mac .dmg file?Thank you.
Hi @Max31,
Can you run the SystemInfo command and post the results in a reply?
— Dale
Hi Dale, I’ve run the SystemInfo command and have the following info was displayed:
"Rhino 8 SR36 2026-10-20 (Rhino 8, 8.36.26293.11002, Git hash:master @ 824eaa40694d0076394d36eac84fb3109a9f5f62)
License type: Educational Lab License, build 2026-10-20
License details: Cloud Zoo
Apple macOS Version 26.6.2 (Build 25G83) (Physical RAM: 24GB)
Mac Model Identifier: Mac17,9
Language: en-GB (MacOS default)
.NET 10.0.8
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M5 Pro
Color LCD (1512 x 982 @ 120.00Hz)
BenQ EW3270U (3008 x 1692 @ 60.00Hz)
GPU Vendor: Apple"
Hi @dale, any update on this?
@Max31 I made a couple of changes to the python 3 installation and how it specifically handles ssl connections which I think is the main issue. Would you mind trying 8.37? I will DM a link
Hi @eirannejad I’ve tried running the ScriptEditor command in the 8.37 version and the install bar gets further than before but the process just stops loading again with the bar slightly further along. There still seems to be some small issue holding things up.
Would you mind running hidden RhinoCodeLogs command and DMing me all the contents when the editor gets stuck? if the whole Rhino gets stuck, then zip up the ~/.rhinocode/logs folder and DM me please
Thank you and sorry for this breaking. Highly possible something changed somewhere else as I have not made script editor changes in 8 in a long while
