I know this post is a couple of days old, but I am really struggling here to create / insert my own title block. Inserting yours works perfectly, but mine is not.
So far I have tried to draw my title block in top view, create a block, name that one and export / save my drawing as dwg. If I open a new file then and try to insert that previously saved dwg nothing appears in either my model space nor on the layout page.
I have tried the same with drawing in the layout space, save/export etc…but again - nothing appears on my screen.
Is there any tutorial which shows (exactly) step by step from scratch how you / one has to create such a file / block so itcan be reused in every project? My workaround with drawing it when needed is a little bit time consuming.
I have also attached the info from the bar about my block instance, if this helps:
Per usual, I need your files. It is impossible to trouble shoot based on an image.
This applies to this issue an any other issues you are having.
We also need your Rhino SystemInfo and a “step by step” so I can duplicate it here.
Please send me your title block and the other details by email tech@mcneel.com Attn Mary.
I will let you know what the issue is, after I have had time to work with your title blocks.
Can I assume you are inserting it on the Layout?
Look forward to your files.
Thanks,
Mary Ann Fugier
Thanks @Carl_Mesrobian for sending the title block and working through the best way to make a title block in Rhino.
According to your wishes to share this with the Forum, I have created this thread.
