Tips for tolerance in booleans?
Hello I have to work with a lot of booleans What I do is create the yellow cylinder next create a circle with the same diameter using de center offset it to the correct tolerance and then run wire cut. there is a way to simplify this ? tips please…
Why would you not just OffsetSrf the yellow cylinder?
I dont know lol, Thanks …
solved ?
there is a way to apply the command in multiple objects in the result be grouped?
You can run it on multiple objects, then run SellLast to get the result and group that.
Nice thanks guys.
