Please see the attached file with polysurfaces imported via .ifc from Revit. It’s a model of a 2 timber trusses. I’m interested in using VisualARQ to detail the joinery (notches, drill holes, etc.) between the columns, beams and braces.
I have also attached a copy of the .pdf shop drawings, which shows the details of the connections that need to be made in 3D.
Has anyone done this kind of work in VA before, or are there any suggestions for doing this kind of work? Should I just bring in a 2D .dwg of the truss drawing as a reference, then either manually (or using GH) make closed polysurfaces for boolean difference operations?
Is there a good way to do this all in VA and Rhino?
Thanks,
Dan
2017.7.3.CRANBROOK.HISTORY.3dm (2.8 MB)
2017.7.3.CRANBROOK.TFSD.pdf (1.5 MB)
