In the latest beta trying to use this on a layout detail with a typed angle is not working. Dragging does.
Hi Jim -
I activate a detail that shows a top view. Running the following macro seems to work as expected here.
TiltView Angle 10 Left
Right - previously, the command would execute when you put in an angle and hit enter. A positive angle turned it one way and negative the other. Now, you define the angle and then left or right executes the command. Seems fine to me this way, but it did change at some point.
That is…not obvious, given how every other place in Rhino where you enter an angle works. There’s nothing explaining that’s what you have to do.
Yea…
It looks like someone had issues with the previous behavior…
RH-97605 TiltView: Angle option now sets the angle used by Left and Right options
-w
